Fast SSS and bump
  • Fast SSS and bump
    I'm trying to figure how can i make a skin shader with the vray fastSSS and a bump map.
    The problem is there isn't bumpmap slot in the vray FastSSS shader.
    I know the right workaround is putting the fastsss map on top of a vrayblend map.
    But, where i should put de bumpmap?
    www.gaell.com
    Normally you would put a specular (or specular+diffuse) material as a coat material; this is where the bump map should go.
    Best regard,
      How can i do the color of the coat material doesn't affect the colors of the base mat?
      www.gaell.com
        Use a VRayBlendMtl material in Additive mode.
