sp3 vector displacement
  • #31
    This is my try with vector displacement. What do you think?
    higher resolution
    • #32
      yes! the heck, how did you do it?
      Marc Lorenz
      ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
      www.marclorenz.com
      www.facebook.com/marclorenzvisualization
      • #33
        Originally posted by RErender View Post
        afaik that image is showing volume fog not vector displacement
        The way it reads I think it is vector dis, the Environment fog is just above it.
        Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
        • #34
          higher resolution
          Love it can you show us the map?
          • #35
            Originally posted by ^Lele^ View Post
            Grass would look like a blue and black noise, with VERY slight R/G overlayed noise to bend the strands around.
            Try with different mix amounts, and you'll see.
            As Lele said. There is 3 displacement maps - for R, G and B mixed together. All of them is based on the same noise map.
            By the way - switch "Use object mtl" is not working when Vector Displacement is used. Is this normal behaviour? Vlado?
            Sorry for my English...
            • #36
              Yes, it's normal. The 3ds Max materials do not support color displacement maps - they just return a single number.
              • #37
                Procedural or bitmap? Mind posting the map? looks useful.
                • #38
                  Procedural max noise map.
                  I'll post max file later
                  • #39
                    made these with a gradient ramp the other day
                    Eric Boer
                    Dev
                    • #40
                      OK - here is max 9 file.
                      This is my small contribution to this very usefull forum
                      • #41
                        Oooh excelente!
                        Very clever setup.
                        Thanks a lot
                        • #42
                          Originally posted by Shimakaze View Post
                          Oooh excelente!
                          Very clever setup.
                          Thanks a lot
                          i agree very clever, i actually dont have a clue what u've done here lol :s
                          Tarik
                          • #43
                            waves
                            How are waves created? An ifl of exrs off a surface created with Glu or Realflow?
                            • #44
                              me neither, will just save the map for future use !
                              • #45
                                So you could take any old b/w displacement map into photoshop, fill the red and green channels with black and you would end up with the vector displacement equivilent of the standard displacement map. May be useful if you already have a good grass displacement map, then experiment with mixing in the red and green procedurally as Mnietek has done.
                                Ben Steinert
                                pb2ae.com
