Ambient Occlusuin - side effects
  • Ambient Occlusuin - side effects
    Here are two bad side effects only apparent when using AO:
    In this image the lights - generate a negative light
    In this one the light has a dark halo between the light and wall
    the the only difference between both images is that the interior one has a shutter speed of 80 and the exterior of 100.
    EDIT: After turning AO off it lingers but it wasn't apparent prior to using SP3
    Could it bee due to using photometric lights ?
    or using the VrayLightMtl direct lighting ?
    Nir
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    I would be very cautious to use AO in interriors.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      BUT AO is most "appreciated" in interiors....
        This doesn't answer your question at all (this should probably be in the problems section) but I tend to agree with MA. At least do it in extratex and comp it in after.
          I am not sure thayt the reason is AO but those black areas only appeared AFTER I switched the AO ON ans worse - they did not vanish after Turning it OFF....
          NIR
