AO & animation prepass
  • AO & animation prepass
    first of all being new to this forum I have to say HELLO, hope to be welcome here and to benefit from this community;
    I'm not a v-ray newbie but its not that long I switched from MR ( currently mainly working with max2009/64-design, acad, rhino (never tried v-ray for that) and some basic postpr.)
    SO I'm kind of autodidact concerning vray ( with francesco's "bible" being one of my few resources which is somehow outdated a little bit concerning the new features of SP3).
    I recently posted this in the open forum as I had no access to another section so some of you already might have read my post;
    most of my work is architectural visualization, so in most animations i produce theres not a "lot of action" but always enough not to be able to apply any of the typical FLYTHROUGH procedures ;so I'm used to render with IrrM & LC with anim.-prepass in most cases ....
    the first question I had concerned anim-prepass & >use cam-path< which I've never opted before<, this question is obsolete by now; well this one was a real rookie-thing but at least I know better now, well thats part of the learning curve I suppose;
    my next question is about ambient occl. ; I'm familiar with the principles ( cause like told i worked with mr for a long time) but I'm not quite sure about the "workflow" of vray regarding AO "baking" the IRR map for animation ; as the LC-IRR map combi. depend on each other and you just need to render from the baked IRR-maps for the final "pass" in animation, will the calculation of AO be an extra "pass" or could one include it into the whole process of preparing an IRR-map precalculation ?
    to ask as elementary as possible: when calculating IRR-maps for animation (anim. prepass) > do I have to opt. ambient occlusion on or off if i'd like to use it, at this point ?
    thanks for any advise in advance ...
    best regards nj
    You can use the extratex element to render the AO without affecting the scene, then just work as normal and add the AO pass in post to your liking
    Oh and welcome to the forum
    Eric Boer
    Dev
