proxy memory footprint: copy vs instance
  • #16
    Hello,
    I tried to Maxscript/Run this script as you said but nothing happened, nothing executed.
    Then I tried Maxscript/Open Script and scipt was open so I made Ctrl+A and tried dragging the script to a toolbar. But I got an error message :
    Compile error: nested macroscript definitions are not permitted.
    In line: mamacroScript V
    I am using Max9.
    Is this the problem?
    for my blog and tutorials:
    www.alfasmyrna.com
    • #17
      ... run the script
      go to customize
      > category vray
      and there is
      > vrayproxyinstancecheck
      bring it to a toolbar
      execute it from there !!!
      • #18
        Thank you very much for your reply I will try this.
        www.alfasmyrna.com
        • #19
          I got that script, used it once or twice with no problems.
          But now whenever I try to use it I get
          "type error: call needs function or class, got: undefined"
          And this pops up in maxscript:
          macroScript VRayProxyLister category:"VRay" buttontext:"VRayProxy instance check" tooltip:"Check for VRayProxy's with the same .vrmesh file" (
          local res=queryBox "VRayProxy's with the same .vrmesh file will be converted to instances. Are you sure?" title:"VRayProxy instance check"
          if res then enumVRayProxies()
          With the bolded line highlighted.
          I just started with a blank scene, merged a proxy in and copied it around a few times to test it and it's still doing it.
          Any ideas?
          Weird that it'd work for a bit then break.
          • #20
            You can try to change the script like this
            Code:
            if (res==true) then enumVRayProxies()
            however in any case the error means that the queryBox function did not work for some reason. Which version of 3ds Max are you using?
            • #21
              Same error, and I used the "if (res==true) then enumVRayProxies()" command
              with an error of:
              "-- Type error: Call needs function or class, got: undefined", again
              Using Max 2010
              It worked once, but not a second time.
              UPDATE:
              It worked after I added the command to my vray tools menu item again.
              • #22
                Any ideas?
                that happened to me also.
                It need to be loaded everytime you opened a new max session.
                Put the script in max startup or run it every time you open new max session after that hit the button at toolbar.
                --Muzzy--
                • #23
                  Could you add something to this script, so after it runs - objects that are instanced now were selected?
                  Thanks
                  Z-Dimension WIP 1 WIP 2 WIP 3 WIP 4
                  • #24
                    I could do that, but keep in mind that they may not all be instances of the same object.
                    • #25
                      It`s not a problem! Thx
