I don't really have time to RND this right now, but is it possible to bake proxy lets say ambient occlusion to the uv texture?
Can one bake proxy to uv?
Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
https://www.linkedin.com/in/dmitry-v...-identity-nameTags: None
Originally posted by vlado View PostYou can only bake normal meshes for the moment, so you'll have to import the proxy as a mesh.
VladoDmitry Vinnik
ShowReel:
Originally posted by vlado View PostWell, it will be a long waitYou can probably render from a few angles and stitch the result with projection mapping or something... or just calculate this in the normal way.
Vladowe have multiple uv tiles spread out across several uv squares. I'm not even sure that's possible to bake in side max unless you separate each uv tile on individual map channel, but that would not be possible with a 16 million poly mesh...
Dmitry Vinnik
ShowReel:
