Hi, i'm +
trying to cross the gap to the LWF thing.
i'm reading everywhere that in some cases, whatever method you choose to use, you have at one point or another, to apply gamma correction, whether you need to actually correct the image, or uncorrrect it/
i was wondering what is the method to apply this correction
i have read that sRGB is a 2.2 profile. so, to correct an image (let's say i want my images to have a 2.2 gamma in them), do i simply need in photoshop to convert the image to sRGB profile ? or do i need to discard all profiles and apply a manual gamma/exposure correction ?
also, in phnotoshop, there are two options for profiles. in french it's called "convertir le profil" or "attribuer un profil". i think you can see the english correspondance. which one to choose ? (in case this is a method to gamma correct an image of course)
i really want this lwf to work, but this is such a mess with all those redundant options in all softwares, even in the same sotware, settings can override each other it seems(i'm thinking of gamma lut in 3ds max, crossing with color mapping in vray for example)....i'm a bit lost for the moment, but i have good hope.
Thanks
for info i have an lcd monitor, so i'll try to work in linear space, but i don't know yet how to calibrate my monitor to gamma 1.0... and most of the images i work with have an embedded sRGB profile... so i think i need to "uncorrect" them before using them.
sorry if the post is difficult to understand... it only reflects that all this is a bit hard to understand for me at the moment.
Thanks for reading
Thanks
Thanks for reading
