I have to render several long animations with a lot of vegetation and run into some antialiasing problems with Vray proxy trees.
I tried to render with Adaptive DMC set on 1/6 with adaptive amount:1.0 and Noise threshold:0.01 and the "Quadratic" Antialiasing filter.
The GI is working fine with Irradiance maps precalculated with the "Use Camera Path" option.
All Buildings look good but there is a lot of noise on the trees,
especially in the distance.
I tried to remove the noise in after effects, but its simply too much.
Has anyone run into the same problem?
I cant simply raise every setting because of the rendertime and upcoming deadline.
Maybe using the "fixed" type image sampler will help?
Here is a small cropped area from the HD Version,
i cant show much because of the NDA:
www.vector-film.de/AAproblem.wmv
kind regards,
tammo
kind regards,
tammo
