Help with animated HDR sequence
  • Help with animated HDR sequence
    I have an image sequence of an animated sky in hdr angular map format that I wanted to experiment with. Is there any way to use an image sequence within the VRay HDRI map? The only workaround I can think of would be to transform each frame into Spherical format and use the standard bitmap loader but that would be a right pain.
    Any help? When I did a search on here I read somewhere that Vlado may have a script for this. If so, and you read this Vlado, I would love to check it out if possible.
    Thanks.
    Check out my models on 3dOcean
    If you create an .ifl file sequence, you can specify that in VRayHDRI.
      That worked perfectly, thanks a lot. I never even knew about the IFL Manager utility before!
