texture help
  • texture help
    Hi friends...
    just help me to find out this (stone or tile)
    Thanx in advance
    If you stand far enough, you could use a procedural tile map, In the advanced roullout, Tiles setup, add you tile bitmap in there, and play with Color Variance values.. It will play with each different tile color, a little or a lot depending on the values.
    If you are too close, I guess you will need some geometry / manual work
    Alain Blanchette
    www.pixistudio.com
      maybe this tool might help you out?
      it's posted before, but long time ago and you might have missed it.
      http://www.brick.com/md/index.htm
        Thanx...
        Hi....thablanch...I am trying that....
        Hi..joost..That down loading not working...thanx...
