how do i use skylight portal?
  • how do i use skylight portal?
    hi all,
    how does one use the skylight portal feature
    in vray area lights?
    i tried creating a planar vray area light, checked
    on skylight portal (and had my environment light
    in the main rendering dialog turned on)
    but when i render, its all darkness.
    i'm guessing the skylight portal means what is
    sounds like? ie, having the environment light
    stream in thru the defined portal?
    thanks all
    i would like to know that, too.
    Reflect, repent and reboot.
    Order shall return.
      you need to switch on GI in render settings
      P
      Room lit with sklight portal set into opening in ceiling and GI switched on
        Paul, can you post the file so the set up can be examined?
        Thanks!
          portal
          Please paul, i get the dark image 2
          thanx
          mauarduz
            heres the file guys
            www.kea.uk.com/portal.max
            heres another image using 4 skylight portals
            this may not be correct but the way I understand skylight portals is you still need the opening in the geometry ie. the window . You then place the vray light within the aperture and select skylight portal . The vray light then acts as a distribution point for the skylight
            P
              i dont understand. if there is a hole in the mesh the light from the sky will shine through anyway. so why put a vray light there?
              Order shall return.
                Skylight portal
                Think of it more as a lens that focuses more of the environments light in through the opening. You should see a substancial increase in the ammount of light reaching into the room when using portals.
                Signing out,
                Christian
                  Paul, thanks!
                  Trixian - love the Mononoke avatar!
                    skylight portals
                    How long did that scene take to process the irr. map w/ your vray lights? My interior scenes take extremely longer to process compared to my exterior scenes.
                    ST
                    Indecisive archictects will be the death of us all.
                      P
                      thanks paul. didn't think abt having an opening still.. i thought
                      that it wld work like an area light but just with a skylight style
                      of light distribution.
                        doesn't work
                        paul-G: I have downloaded your scene. It works pretty good, but I've tried to make the same and my scene deons't work ;(((
                        I have checked all the settings - really everything, but in my scene it doesn't work.
                        Couldn't you write step-by-step how to make working skylight potral?
                        Thx!
                          Janper,
                          why dont you try looking into www.vray.info or searching the forum? You mite find what your looking for there.
                          -dave
                          Cheers,
                          -dave
                            janper, make sure you have the vray environment on and overriding max's.
                            5 years and counting.
                              With the portal function you can have GI shadows with very low irradiance settings, because the portals really cast shadows, see example:
                              (rendering takes longer because there is sampling needed for the 'portal light shadows')
                              Same img with portals turned off and some multipliers turned up to get +-same lighting level in the interior, notice the lack of shadows. Irradiance map settings are set way better here because with the low settings from the previous img the GI is super blurry. Actually I don't know if in real life situation shadows would be more like this image or the previous...
                              But when using windows with other shapes or curved windows, the portals are quite useless imo.
