Gold material turns green
  • Gold material turns green
    When I try to create a gold material and I put the same color in the reflection swatch, the reflection turns out green. It looks like a negative value is returned.
    Why is that?
    the screenshot attached has one with background and one without.
    Nils Poetoehena
    3D Visualiser
    www.demanufacture.org
    www.gielissen.com
    Try to set the "Energy preservation mode" parameter in the Options rollout of VRayMtl to "Monochrome" and see if it helps.
      yeah great! that helped. Any idea why it does this?
      Is this going to affect physical accuracy?
      Nils Poetoehena
      3D Visualiser
      www.gielissen.com
        It helps if you think of the VRayMtl material as a layered one; since the reflection layer reflects away more of the red and less of the green light, you only get some green light and most of the blue light to pass through reaching the underlying diffuse layer.
          that explains
          thx Vlado
          Nils Poetoehena
          3D Visualiser
          www.gielissen.com
            Also, bare in mind that the "diffuse" component of metals is close to black. Setting the diffuse color close to black will also help, and keeps the shader closer to reality.
            A.
            credit for avatar goes here
              So most of the color of metal is caused by the reflection color? I'm always having a hard time creating convincing metals
              Good tip! thx.
              Nils Poetoehena
              3D Visualiser
              www.gielissen.com
                Yes, same as glass. Only with glass you use the fresnel reflection, and the amount is almost white.
                www.hrvojedesign.com
