Light Animation Error?
  • Light Animation Error?
    Hi, I have my Scene with one animated VRay Light and an animated mix map with two HDRI´s in the Enviroment. I rendered it with the Multiframe incremental Method (every 10th frame, stored Irradiance Map and used it).
    For the GI I used the the Medium Animation Preset, and tried some custom settings.
    Now I got the Problem that (as the Camera moves) the Scene doesn´t refresh the Light changes properly. The new parts, which get visible as the Camera moves, are correct, but the other ones are darker (since in the beginning the Light and the HDRI was darker).
    Thanks Schnupps
    If you animate the light values, you can't use a saved solution since the solution changes for every frame. You must render this animation in single frame mode. Try the medium animation preset
    Torgeir Holm | www.netronfilm.com
      try this link for more info:
      http://www.chaoticdimension.com/foru...pic.php?t=1961
      or...http://www.vrayrender.com/stuff/Manu...vancedimap.htm
      maybe that helps.
      Corey Rubadue
      Director
      Chaos Group
        Thanks for the answers, I thought Single Frame would result in flickering, since the Irradiance Map of each Frame has no relation to the one before.
        Suppose I was wrong.
        Thx Schnupps
