lightcache passes
  • lightcache passes
    What does the lightcache passes actually do? I built a little render farm with 5 - i7 with 12 Gb DDR3 per box. I rendered a scene with the default 8 passes and it took 28 minutes. I rendered the scene using vray dr and the default 8 passes and it took 5 minutes (sweet) and then I rendered the same scene with vray dr and 24 passes and it took 6 minutes 30 seconds.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    lightcache passes = threads.
    if you got 8 cores you have to use 8 threads, otherwise some cores will idle.
    using more passes will reduce quality though. it's like blending multiple PPT images together...
    Marc Lorenz
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
    www.marclorenz.com
    www.facebook.com/marclorenzvisualization
      cores
      So if I have 44 cores do I put 44 cores for my passes? The vray help says put 1 for best results. The more cores the slower it goes and the quality denigrates so I am not seeing the benefit of more cores for lightcache passes.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        sorry, I should have been more precise...I meant CPU cores of single computers, not all together...
        with the core i7 and hyperthreading you should use 8 lightcache passes, in order to keep the CPU busy...
        with render farms you should use the max number of cores that is used by any computer in the farm.
        so sticking with 8 is fine, unless you got extreme hardware with even more cores in your farm.
        the reason why vray is not using all cores by default is because the output may be different between frames (flickering), when the number of passes differ.
        if you're only rendering on a dual core notebook for example, then you can reduce the LC passes to 2.
        that's how I understand it.
        Marc Lorenz
        www.marclorenz.com
          lc
          gotcha... so 8 cores, the default, is what I'll stick with
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
