router/switch
  • router/switch
    Howdy all-
    I am running 5 machines, 4 being slaves running vray spawner. Currently I have an old 100mb switch and I am wanting to upgrade. Is a gigabyte switch of any value to me or is 100mb sufficient.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    If you have all your textures being lifted from network drives, then I'd use 1000mbit switches. I've found the performance increase isn't 10 times like you'd think, but it's better than 100mbit for sure. All your cabling will be the same and will work with a gigabit switch, so you may as well change up. They are inexpensive also.
      yes, what judderman said
      Kind Regards,
      Morne
        definitely worth the upgrade - the cost is pretty nominal for a 4port switch. At 4-5 ports you might even get a wireless router that will do the trick all in one.
        b
        Brett Simms
        www.heavyartillery.com
        e: brett@heavyartillery.com
