Animated Proxy Rendering with Black bits
  • Animated Proxy Rendering with Black bits
    When I render out the scene with the animated proxies, they have black bits on them randomly flickering from frame to frame;
    http://www.inlightin.co.uk/images/Proxy%20Mess.jpg
    Apologies for the small image bit the strange thing is that when I render at a higher resolution, the black bits get smaller but are still there.
    Has anyone come across this ?
    Thanks for any help.
    N
    I am unable to view your image...
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thats a bit strange, anyway, I hope this works.
Name:	Proxy Mess 2.jpg
        Any ideas would be helpful.
          what GI methods are you using?
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
            Irrad map and LC.
            There are alot of settings and little techniques that I am using so, what specifically are you referring to ?
              Im just wondering if using a single frame GI approach will clean that up
              Chris Jackson
              Shiftmedia
                I tried pre calculating each frame and it helped, I think there are a number of factors that caused the problem and there is no one thing that I can say has solved it.
                It either happens or it doesn't.
                As soon as this project is over, they are getting binned.
                  wait. your saying you used a precalculated map on a moving object?
                    yes i believe your right
                    Chris Jackson
                    Shiftmedia
                      Believe it or not but, I used the method for a static animation and it worked brilliantly but you have to make the moving objects not visible to GI.
                      For no good reason all of a sudden these black bits started to appear after numerous successful tests.
                      The black bits still show when I render still images with their own Irrad and LC solutions so, the method above can't be the cause. Also, when I render the image at 3000 pixels - the black bits are still there but alot smaller.
                      Its all very confusing.
                        Ok - the solution to get rid of the black bits;
                        Untick 'Check Sample Visibility' in the Irrad Map rollout.
                        Can't believe that caused me so much hassel.
