DR Slaves
  • DR Slaves
    Using DR when do the slaves actually start contributing? Currently When I send the scene I'll get a list of hosts, but nothing happens during the prepass. Nothing actually happens until I start/stop the vray spawner when it starts rendering. Normal? If I start stop prior to rendering, during the prespass, it'll say scene loaded, but the slaves don't start contributing until render time.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I would say it is depending on how long it takes to load the scene, your network speed and machines spec. I had scenes that were too small, so the main computer could start the rendering before the other ones were kicking in.
    For the start stop thing:
    For the machines that are running the DR, I do restart them once a day, each morning, and it does the job. No need to restart them during a job, unless there is somekind of "oops" happening
    For the machines using DR as a service.. I think they have been running for over a month without restarting.
    Alain Blanchette
    www.pixistudio.com
      For larger scenes, it may help to turn on the "Compress files on save" option for 3ds Max.
        Are you using a pre-calculated irradiance map? If so and it is large it can slow things down, especially if the server is slow.
          I have tried pre-calculated irradiance map and it works sometimes. I get strange things happening in my scenes so I don't use it often. i will try to compress on save to see if that helps me out.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
