Multimatte and BB Strips Questions
  • Multimatte and BB Strips Questions
    2 Questions;
    1. When rendering with certain geometry set as multimattes - the MM comes out fine except behind glass - it becomes black, is this normal or am I missing something ?
    2. When I render over the network to backburner using strips and save using the Vray Frame Buffer it only saves one strip. Has anyone else found this ?
    Any help would be appreciated.
    Thanks
    N
    Saving from the VFB with Striprendering is not supported. Known limitation from the Docs.
    Wich Version are you using ? SP3 can also have refracted MMREs but you have to set the "affect" dropdown in the refractive materials to "All Channels".
    Regards,
    Thorsten
      Hi Thorsten
      Thanks for that - changing the glass refraction to All Channels was the key !
