http://vray.info/entry.asp?entryID=30
has nothing to do with my Question ...well somthing not really ....
its a odd think stanadard....mat ..works and the v ray mat no ...
also ...
got a tone of obj's....max dont really like them and crash bring them to maya...then use the filmbox exporter to max they look great ...keep the name everything
but its tiney ..!! tiney ...try to world rescale and not everything scales the same .....and getting odd little whoo haaa.....got any thought on ...max scale ?????
I´m getting this problem also, everytime i try to render a scene with some polygons whose normal are pointed inwards ( not facing at the camera) they just won´t reflect a thing!
this is only when i use the vraymtl, with the standard material it renders normally.I also tried with the 2sided material (can´t remember the name now) as root material with the vraymtl as front/back side materials but it was unsuccessfull again.
Of course I looked, and it looked like several of your faces had flipped normals. This can happen when you import models from other formats. Can you post the maxfile and I can take an even closer look.
ok egz, you suggest to apply a normal modifier on top of the geometry, but i need to reflect on both sides of the geometry, that´s my problem. Does a solution exist ?? cause i can´t figure it out!. I´ll post a render showing my problem later. And thanks for reply btw
