Render Element overwrite with Batch render
  • Render Element overwrite with Batch render
    Hi there,
    I already had that problem and can't find a easy way to solve it, here it is :
    When I'm using render elements with the normal "save file" dialog, all my render elements are in the folder where I have set my render output. Till here no problem.
    If I already have done that thing even one time, I have in the render output dialog the name of the latest rendering that I have done.
    Now my problem :
    When I'm using the Batch Render, the output path (and the name of the render output) of the render element still remain the output path of the one of the output path in the Common Parameters. I would like that it could use the output path that I use in the Bath render (and the name allso) :
    So now actually, the only way I have to do it work, is :
    1° Merge all my scene in a new one so that there is no output path set in the common parameters.
    2° Create different render presets for all of my different renders but really boring.
    3° Wait for someone that could help me
    Hope you do understand my problem, sorry for my poor English.
    Stan
    3LP Team
    3LP Team
    about batch render
    hi 3LP, to my understanding, batch render is only specific to a camera's point of view or a light's point of view. but for render elements, i think the path option on the Render Elements Tab is what you should setup if you want the images to be saved in the path specified.hope this helps
