IR+QMC will it be saved?
  • IR+QMC will it be saved?
    A good day to all,
    I just came up a thread mentioning that the light cache will be saved with the irradiance map upon computation and that all you have to do is load up the computed irradiance map/maps and leave secondary bounce to none. Is this also true if you compute irradiance map/maps using the IR+Brute force method? Thank you in advance
    Yes, the information will be saved indirectly - since the secondary bounces are needed only to calculate the primary bounces, once the primary bounces are done, the secondary ones are no longer needed.
      Thank you very much vlado
