Dirt Map
  • Dirt Map
    How do you use a dirtmap with a bitmap? I can't for the life of me figure it out.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    In what sense? As in a bitmap driving it or in combination with a bitmap?
      Dirtmap
      I have brick that I would like dirty. I want to apply my dirtmap over my brickmap. I usually render out a OA pass and multiply it in PhotoShop, but I am trying to avoid the extra work.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        To use Vray dirt:::
        Use Vray Comp texture-
        Put your brick map in first slot-
        Put vray dirt map in second slot-
        Change mode to Multiply
        That's all you have to do!
          Well, I'm normally using dirt in blend material
          Base "clean" material (brick in your case)
          -Dirt material - masked using Vray-dirt
          That way I can control what kind of dirt I get. Dirt is not just darker.
          In some cases it could be lighter. Like dark stone where you have dust
          and sand in small angles. Sometimes it's totally different kind of material.
          Like shiny metal with rusty bumpy edges.
          Dirt should be used to mask other material to wanted areas. Not
          using it as color corrector etc.
          Just my opinion.
          (...and don't be afraid to increase dirt samples alot. Like 100)
          -LarsSon
          Lasse Kilpia
          VFX Artist
          Post Control Helsinki
            I'd tend to do something similar larsson except I'd use photoshop for my dirt - I normally have my clean image, dirty image and then use some photoshop dirt brushes to mask between the two - You can use the masks in different ways to drive your materials quite nicely although it takes far more hand uv unwrapping and so on.
              Yep, that's really good for stills, but might be hard for animations.
              Lasse Kilpia
              VFX Artist
                Dirt textmap in the Blurbeta plugin pack is good too.
                http://www.splutterfish.com/sf/WebContent/BlurPack
                :: twitter :: Portfolio :: My 3D Products :: ...and ::
                  Dirt
                  OK. You guys are helping, but I am getting stuck. The image below shows a box (1) and a poly (2). Both have the same material, but both are reading differently. The box (1) is a test and is working and the poly (2) is a wall that I want to make dirty. Am I missing something?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Mapping coordinates? What's making the dirt? Bitmap or procedural? Also the poly might need some depth / shell thickness to get the dirt to work the same way.
                      dirt
                      Mapping coords was it. I thought dirt ignored mapping, but I am using a map to control the dirt so it makes sense.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I do the same thing all the time - look for a hard answer to something really easy since personally I could have never overlooked something that simple
                          Dirt
                          Now why not just put a dirt texture in the radius slot and your texture map into the unoccluded color slot? it seems to work just fine.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Dirt
                            Can someone take a look at this file and let me know why I can't get my dirt to work? I think it is a scaling issue, but I can't figure it out.
                            Dirt Problem
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Originally posted by 3DMK View Post
                              To use Vray dirt:::
                              I'm pretty sure you don't need the VRayComp Texture to get the results you want (at least for this result). Just put the brick map into the "unoccluded" map slot of the VRayDirt Texture, make sure the occluded color is still black , and you should get an identical result. It should be slightly faster (maybe not really noticeable though) since it's a little less math for VRay to calc.
