Hi. Has anyone experienced this sort of network rendering problem. We do mostly arch vis stuff in our office and the usual technique is the saved irradiance map from an incremental add to with low AA settings thing. The weird problem is this. Some frames turn out different, what I mean by this is that it is a bit darker than the other frames. Sometimes some lights even look that they were turned off. Sometimes the thin elements of the rendering (thin geometry) look darker than the rest. I was able to narrow it down to one machine, so I thought that it was just something wrong with that slave because re-rendering the frames in the other slaves corrected the problem. Now after sometime I tried using that malfunctioning slave again. Surprisingly it went well in the beginning (2 render jobs of 600 frames distributed). On the third job it acted up again rendering darker frames, NOW the weird thing was is this time it wasn't just that computer that acted up but also another computer.
Just for reference, all computers are running the same version of Vray (1.09.02U). All have the same plugins (network rendering won't work on a machine if that machine is missing a plugin) and map paths. Has anyone experienced this problem. Its becoming a really annoying since now it seems to be appearing randomly (sometimes ok, sometimes not) and now its happening on 2 of my dual processor machines (a waste of resource). Any help would be much appreciated.
Joel
Joel
