I read on this board somewhere about creating a standard material, setting the self-illum value to a color and then using an output map in the Self-illum slot.
I assume you were supposed to adjust the RGB level to control the light strenght -- but then results in the light turning white.
What is the proper way to do this? Or maybe I should ask -- is this tip now completely useless since the Vray Wrapper has the Generate GI controls???
Is there any difference between the two methods as far as quality or control?
