FlyWiz - Flythrough animation wizard free script
  • FlyWiz - Flythrough animation wizard free script
    Hello everybody,
    i've made a new script wich helps to manage Flythrough animation stuff..
    Some buttons are here to help for quality control before launching each step of this kind of rendering.
    The script makes proposals for LightCache subdivs and "render nth frame" for irrmap. it also change the lightcache scale to world/screen depending of your choices.
    the other vray values (lightcache sample size, irrmap quality, sampler quality) have to be set manually.
    The script is mainly an automator avoid to make lot of clicks and changes for each different step.
    FlyWiz can also automate the whole sequence if your settings are already ok. no need to stay front on your max to render lightcache, then irrmap, then final passes. it do all that for you, you can go to bed
    This script is free, you can use it for personnal or professionnal work.
    The only thing is a little advert for my other plugin SolidRocks inside the gui. Not a big deal
    Tutorial/demo video is here : http://solidrocks.subburb.com/index....d=39&Itemid=40
    FlyWiz download link : http://solidrocks.subburb.com/index....=38&Itemid=110
    Hope you'll like it !
    Jérôme Prévost.
    SolidRocks, the V-Ray Wizard.
    Thanks, will certainly give a try.
      heh thats really neat! thanks a bunch!
        Thanks for that nice little script, will try it SAP
          Nice..thanks i will try it in my next anim...
            That's something I've been working with lately. Good to see a more automated way of dealing with it. Can't wait to give it a whirl.
            -Chippy
              merci, i'going to try it right now !!
                Fly
                great script, thanks. I am trying it and all is well, but it is rendering out every tenth frame for the pre-cal. Your video doesn't address that.
                Bobby Parker
                www.bobby-parker.com
                e-mail: info@bobby-parker.com
                phone: 2188206812
                My current hardware setup:
                • Ryzen 9 5900x CPU
                • 128gb Vengeance RGB Pro RAM
                • NVIDIA GeForce RTX 4090 X2
                • ​Windows 11 Pro
                  Pre-Calc
                  Is anybody having this issue or am I doing something wrong?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Hi !
                    well you're right i forget to mention that IrrMap is computed every N frame into the video. I'll add the info, thanks.
                    The irrmap is computed every N frames. If you choose "Walk" then it will be every 10 frames, and if you choose "run" it's every 5 frames". You can also override the value in the script using the spinner.
                    In resume :
                    - LC is computed 1 time for the entire animation
                    - IM is computed every N frames
                    - Final frames are all computed.
                    Jérôme Prévost.
                      Animiation
                      But should it me doing a final render of the IrrMAP?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        well i'm not sure to understand your question....
                        Jérôme Prévost.
                          Animation
                          When it is doing the Irrmap pre-calc, every n frames, it is creating a still for each "n" frames. Should it be doing this?
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            yes, but they are useless. i was sure that they'll be deleted after the pass. i'll check that point.
                            They are generated only to avoid annyonning max warnings about render loss.. that's the only way i found to stop these warnings. (non-catchable via maxscript)
                            Jérôme Prévost.
                            • #15
                              Animation
                              Gotcha, thanks.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
