I know there are many visualisers here using Vray so i thought i might put this topic up as it has plagued my vray network rendering for a while and i could not find any information on it myself. Its to do with the Design extension plugin for max, it was giving me errors on all my rendering machines (bitarray.cpp error and missing filelink.dlu) when i sent a project from a my local machine (which uses full license max and design extension.)
It seems that des. ext. requires a full version of max to install as it opens max during installation. Obviously when you just run the network rendering install of max on the render nodes you cannot install des. ext. properly as it can't initialise max. I thought that i could get around this problem by just copying the plugins from my local machine to the render nodes but this just gives me filelink.dlu could not initialise.
Anyway, it turns out that the render nodes don't actually need the plugin but an empty folder named filelink placed in the stdplugs in the max directory (why this is so I have not found out yet ) and then it renders fine
fingers crossed there will be no more problems.... I will try and put this up on the discreet support site too to get some more answers
