VRaySphereFade
  • VRaySphereFade
    I tryed to use it on my 64 bit version max/vray XP64 windows, but it does'nt work.
    Is it only for 32bit versions?
    Don't anyone knows is?
      Come on! someone has to know it!!!
        what version of vray are you using?
        Chris Jackson
        Shiftmedia
        www.shiftmedia.sydney
          What do you mean it doesn't work? It gives an error? There is no effect when it is enabled?
          Are you using a sphere gizmo and Picking it?
          To answer your main question -- It does work on 64-bit OS, with max 64.
            I use vray 1,5 sp4 with 3ds max 2010. When the plugin file is in the folder, and I startup max, a error box appear...
              I have now tryed to reinstall but without any difference...
              This is the box that appear when I start up max..
              Can anyone confirm if this plugin isn't made for 3ds max 2010....
                ummmm looks like you are trying to install a really old version of vray.
                the fadesphere DLR for max 2010 is called vrayspherefade2010.dlr
                Chris Jackson
                Shiftmedia
                  hmm I found the link in this tut "http://www.spot3d.com/vray/help/150R1/tutorials_anim.htm"
                  and it worked fine in my 3ds max 2009 Vray 1,50 sp4
                    you dont need to install the plugin separately. Its included in the standard installation now
                    Chris Jackson
                    Shiftmedia
                      ohh
                      Thats why it didn't work
