There was recent discussion regarding the usage of HDR images for lighting. I mentioned that I thought it would be good if we were to come up with a scene and compare/test various lighting methods to see what achieves the most realistic look.
So here is a very simple scene to download.
The original model appeared in this post by Zahir3D, but I have gone in and changed the house around such as some of the geometry and textures as well as added a few items. The overall scene itself isn't very impressive, but that's the whole point here - is to see how we can make it look better by simply adjusting the lighting.
I've set some very basic settings for the sake of speed and running tests.
The rules follow:
What you can't do:
What you can do:
The default scene consists of:
I've included three examples of the default scene using the Vray Sun with no other adjustments (admittedly, I think they look ugly - but hey, no post processing here...):
The complete scene can be downloaded from here:
http://www.lunarstudio.com/house.zip
The rules follow:
What you can't do:
- No adjustment of Irradiance Map/LC settings.
- No adjustment of DMC sampler.
- No post processing (Photoshop, etc.)
- No curve adjustments.
- No use of color corrections (including applying a s-curve.)
- No adjustments or changes to materials.
- Camera angles must remain so we can see the changes/differences.
- You cannot move or substitute the models.
- Apply frame stamp and processors so we can compare rendering times.
What you can do:
- The sun can be removed or changed.
- You can use an entirely different lighting setup.
- You don't have to use Linear Workflow (but you also cannot post-process.)
- You can adjust the F-stop of a camera.
- You can adjust the white balance, shutter speed, etc...
- You can change the background and environment.
- You can surf the web, etc. while rendering.
- Prefer daylight settings if possible.
- Burnt-in LWF.
- A Vraysun with minor adjustments (extra subs and lower turbidity.)
- Very plain Vraymats other than a little Vraydisplacement.
- Three Vray Physical Cameras to show different angles - slightly adjusted.
