DR problem
  • DR problem
    I am having problems with one of the nodes in my system. The node is on the same computer I use for interaction and has always worked before. It now renders without irradience and bitmapped textures. I have checked the bitmap paths to verify unc paths. all other nodes work and it renders fine an the same machine when not using DR. Whats going on?
    I have reinstalled the DR components and the problem persisits on all my files. The computer in question renders fine until I use DR, then it renders kind of a shaded black and white image no textures or irradience.
    Could the problem be in my 3dsviz.ini.
    other info:
    Vray build:VRay 1.09.02u
    Windows XP Pro dual xeon 2.8 ghz
      I discovered that the macro recorder was left on so I turned it off, shut down VIZ and Spawner, restarted both and it fixed it. Really freaky!
