Really need help- Vlado?
  • Really need help- Vlado?
    The computer I use as my main workstation no longer works with DR. It works fine when used for non Dr rendering but not when used as a node for rendering. The problem appears to be with bitmaps. The images render without any bit maps. The GI works fine. It's strange because all the other nodes work fine except for the one I also use as the main workstation. The main workstation renders fine but not as a DR node. It has always worked before but started this yesterday.
    Problem solved
    I discovered that the macro recorder was left on so I turned it off, shut down VIZ and Spawner, restarted both and it fixed it. Really freaky!
