How to comp vrayfastsss2?
  • How to comp vrayfastsss2?
    Hello everyone,
    How would like to know if someone know how to comp a a vraysss2 render elements with the diffusefilter pass,the rawlighting pass, the GI pass,...?
    Because when I use the add or screen mode is a bit to shiny compared to the full render.
    thanks a lot for your answers.
    ps: sorry for my english
    The sss2 element should be added to the rest of the channels. Note that the sss material may also produce a diffuse portion, which will go into the respective diffuse elements (lighting etc).
      This is some screengrab from a flint 2009
      When I comp a diffusefilter pass with the RAWGI pass I obtain a Vray GI pass
      When I comp a VRAY SSS pass with a Specular pass I obtain my full render
      Logically when I multiply my diffuse with my RawLight I obtain a lighting pass but in this case the lighting pass I render in the render element is black .
      And if I try to comp all the layer with the sss I can't reproduce my full render.
      ps: sorry for my bad english
      thanks a lot
        Ok, I see the problem... the SSS shows in the diffuse filter element with its full color, which is what causes the problem. Will make a note to fix it, but until then you'll have to mask the SSS object from the diffuse filter element.
          Thanks a lot Vlado
          I am happy to read this. I don't use sss pass wit the diffuse filter anymore until there is an update.
          thanks for your hard work
          regards
          mickael
