Saving render elements within one EXR when rendering through BACKBURNER
  • Saving render elements within one EXR when rendering through BACKBURNER
    Hello guys,
    i am having troubles settign this up...can you please help with the setup?
    Thanks
    Martin
    Martin
    http://www.pixelbox.cz
    rendering to a single EXR via the VrayVFB works just fine via Backburner.
    Regards,
    Thorsten
      i am absolutely sure it works fine, but i just dont know how to set it up the elements saving.
      do i just select the lements in render elements tab?
      do i have to add them when saving to exr (save to exr pop up window)?
      thanks
      Martin
      Martin
        Martin,
        - You could select the elements you want in the render elements tab
        - Rename the .vrimg extention to .exr in the Vray:Frame Buffer section
        Thanks,
        Ismail
          yo,
          i was doing that but i was making the mistake that i ve been also saving through the classical save option in common tab!!! so the vrays EXR has always been overriden by the maxes EXR...
          Thanks
          ALL SORTED NOW
          Martin
