What is the deal with BerconMetaballs?
  • #31
    Could we have a Bercon Metaball recompile for Max 2012?
    And also is there any news on that exciting Bercon Iso/Distance Tex shader that was mentioned a while back?
    Martin
    • #32
      And BerconMaps??
      • #33
        I know Jerry is working on the maps but a bit snowed under otherwise, so not quite sure how long it will take.
        Not sure about the Balls though...
        Check my blog
        • #34
          Here is bercon maps for 2012 link
          http://www.maxplugins.de/r2012_files...01_Max2012.zip
          Didn't vlado compile the last version of metaballs for vray 2. Maybe he can do the 2012 version?
          Gavin Jeoffreys
          Freelance 3D Generalist
          • #35
            Great stuff... Thanks.
            Check my blog
            • #36
              Yep, will compile this one for V-Ray 2.0 as well.
              • #37
                You can get the recompiles for 3ds Max 2012 here: http://www.spot3d.com/vray/misc/
                • #38
                  Thanks a lot Vlado, that's great!
                  Check my blog
                  • #39
                    Great!
                    How about the Iso surface plugin - with mapping capability? *wish*
                    http://henrikbclausen.com
                    • #40
                      Everything seems to be working fine except the MetaBallsTextures. Here, it crashes max when I open the slate material editor.
                      Check my blog
                      • #41
                        It should be fine now, sorry about that.
                        • #42
                          Im assuming you cannot use particle flow cache when using this plugin ?
                          Regards
                          Steve
                          My Portfolio
                          • #43
                            Why not? It doesn't care how the particles are computed.
                            • #44
                              That's what I was thinking, but every time I add a cache mod it crashes vray on render..
                              Regards
                              Steve
                              My Portfolio
                              • #45
                                Can you attach a scene with the problem?
