bumpmap & skylight
  • bumpmap & skylight
    Is it normal that you cannot see a bump effect when using only skylight for lighting?
    here's n example:
    with direct & skylight together:
    with only skylight:
    Yes
    /Thomas
    www.suurland.com
    www.cg-source.com
    www.hdri-locations.com
      Yes, I think so! And its good in this way, just try to use Vraydisplacement and youl will see the difference in render time with the irradiance map calculation.
      Gonçalo
        the real problem is:
        it would need a much higher sampling and therefor produce more flickering.
        robert
        I'm registed believe me! Just miss that logo.
          You need some diversity in the skylight color in order to make the bump visible - make one part of the sky darker than the other, for example, or simply add some objects to the scene to block the skylight in certain directions. This is because the geometry is, after all, flat; if the skylight is uniform from all directions there is nothing that would make the bump map visible.
          Here are some examples:
          uniform skylight: bump is not visible
          non-uniform skylight (checker map), some bump is visible
          uniform skylight with another object in the scene, bump is clearly visible
            Hey thanks!
              bumpmap & skylight
              Try using Comosite Map with two different HDR images for environment.
              It gives dramatic improvement in rendering bump maps.
              Experiment
              Regards
              Pera Zdera
              [/img]
                Hi, your experiment doesn't show up here.
                regards,
                flipside
                  Same here ...
                  Regards,
                  Nenad
                    Which experiment? I can post the scene as well, if you want to check it out...
                      There was slight misunderstanding.
                      When I said experiment I was thinking that one has to experiment and to some tweaking with different settings (multiplier etc.) for HDRi images which constitute Composite map.
                      I didn;t plan to post images because I don;t have permanent web space. I'll try to put images now. ometimes they will be on... but sometimes off.
                      Environment with Comoposite map
                      Environment with simple HDR image:
                      Material Editor screen grab:
                      I used override of MAX environment setting in VRay render dialog
                      Hope it works now
                      perazdera
                        2 perazdera
                        I can see only a red X
                        please change the link
                        I'd like to see your tests
                        bye and thanks
                        Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
                        https://www.facebook.com/essetreddi..../photos_albums
                          Hey Pengo, as perazdera said in the post prior to yours:
                          "I didn;t plan to post images because I don;t have permanent web space. I'll try to put images now. ometimes they will be on... but sometimes off."
                          -dave
                          Cheers,
                          -dave
                          ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
