"Animation with moving objects II" documentation bugs
  • "Animation with moving objects II" documentation bugs
    I was following the Spot3d tutorial and think there is a mistake with this part:
    "1.6.4. Select the Animation(rendering)" when it has to be "1.6.4. Select the Animation(prepass)".
    The images of the tut are lost too...
    Regards
    Originally posted by peprgb View Post
    Regards
    Yes, it would be useful to sort this out.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      Mmmm...the site has been updated with images correctly showed but the "1.6.4. Select the Animation(rendering) mode from the Mode drop down menu." error (if it is..?¿) is yet there...
      (if the correct is Rendering then the next table is bad anyway)
      Regards,
        well, what it should be in the end?
          I recently completed a project where I had moving objects, having not done it before I too followed that tutorial and found many bugs. After completing the work I decided to write a tutorial for it, ironing out the bugs as well as including helpful tips. If there is anything that is incorrect or unclear please let me know. http://www.mintviz.com/blog/flicker-...on-using-vray/
            Thanks a lot for this!
