VMaterial Enviroment map slot
  • VMaterial Enviroment map slot
    well, can somone please explain to me what exactly this slot does. of course it must be something with the enviroment, but itz even more confusing that there isn't any value to tweek.
    and no, i dont found nothing in the VRay help
    for example: am i able to input there for every material a different hdri?
    best regards
    MathTheRender
    emoticom AG
    www.emoticom.ch
    yes, the environment in a material will override global environments locally (VRayEnvironment Overrides, standard max environment etc.).
    Kind Regards,
    Thorsten
      hmm, that sounds simpler than i thought! are there some advices about using hdri's? ...like maybe a certain minimal resolution, or does it behave like a mapped VRayDomeLight? feels strange to me that there arent any more values to tweak, that doesen't feels VRAy like
      best regards
      MathTheRender
      emoticom AG
      www.emoticom.ch
        Minimal Resolution depends on the FOV and the target resolution. What kind of values would you expect ? It's a reflection map. It doesnt override any other reflection settings, nor cast light or whatever. It's a simple environment override.
        Regards,
        Thorsten
          ok, thanks Thorsten for your patience
          best regards
          MathTheRender
          emoticom AG
          www.emoticom.ch
            i believe the order is material environment first if its used, then render settings environment slot next if used the lastly max environment slot
