Viz 4 and Daylight
  • Viz 4 and Daylight
    I recently moved to Viz 4. And now have the advanced version of VRAY -
    Before I begin a project, I am trying to do some test scenes. I create a plane and box, assign a vray material to it. Create a daylight system and render using the defualt settings of AA and setting the map level to very low.
    Everytime I begin rendering I get an error "unhandled exeption:irradiance map thread"
    I originally tried the demo version in MAX, and it seems to work great- shadows and all. Now the scene and shadows are awful, using the same settings.
    Ive attached an image done in Viz showing the test scene. Any help would be apprciated.
    Arkitec
    [img] http://www.sizeler.com/vance/testscene.jpg [/img]
    im not familiar with that light type. IES isnt in max4 i dont think so im not sure if thats the problem. however, if you can post a capture of your render settings that would also be usefull
      Da_elf,
      Thank you for replying so quickly..... I agree with your statement, im not sure about this Daylight system either........my assumption is that is the difference, because everything else (the scene) is the same...
      Regardless, here are the settings.....
      Thank you so much for replying.....
      Arkitec
        Just dont use the Daylight system from Viz 4 in Vray, it doesnt work!
        Use a target direct light instead.
        Gonçalo
          Goncalo is great!
          Goncalo is great!
          Help everyone is in difficult with this great pakage!!!!!!
          I must say that even if I'm not directly interested in this THREAD!!!
          He Is a great professionist it gave suggest to all in this great FORUM
          He does a great support work
          The thanks is necessary
          Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
          https://www.facebook.com/essetreddi..../photos_albums
            looks like you got a fan there buddy
              Thanks Gonçalo.....
              Arkitec
