Using 3DS Max 2009 64bit w/V-Ray 1.5 SP4
I've noticed that when doing final test renders on my workstation, that the render times are much better then when it is participating in the network render of the same project (In this case, a 3x performance hit). This is an animation project using the IR prepass and rendering method. Could this be caused by excessivly high interp. samples and interp. frames values for the IR map during the "rendering" phase? (see attached IR settings below).
How do these settings affect the "rendering" phase and should they be different from the values used during the "prepass" phase?
Thank you in advance for any help - Mega
