Using a render node to calculate LC and IR MAP
  • Using a render node to calculate LC and IR MAP
    Is there a way to calculate the LC on a render node instead of the local computer....and the same with the IR MAP....use only the render nodes and not the local computer also.......so I can continue working on another file. Luckily I have an extra workstation right now....but once a person occupies it I will only have my workstation. Sometime these LC and IR MAP calculations take forever.......or maybe there is some sort of free install without a license that could be put on another computer just to open and do calculaitons without being able to edit????
    A regular backburber job does that.. Just shoot the job to an other machine with the save irr map and lightcache ticked.
    Alain Blanchette
    www.pixistudio.com
