Stereoscopic helper & Irradiance
  • Stereoscopic helper & Irradiance
    when pre-calculating the irradiance map using VRays stereoscopic helper, can you just calculate it for the middle view? would there be any problems/advantages calculating it for both?
    also a bug: turning on stereo red/cyan in the VFB causes vray to hang at the end of rendering, I just leave it off till the render finishes and its ok
    You can calculate it for the middle view only, but there might be issues if some side of an object is not visible in the center view, but it visible in the left or right one.
    Thanks for the pointer about the anaglyph preview, will look into it.
      just to clarify, you can't calculate it for both views at once?
      if there is a problem with objects not quite seen, I guess merging the irradiance is the only way
      btw its been really helpful having it
        This is what it does by default; it calculates both views at once, and they share the same irradiance map.
          apparently (and I guess it's what was R2J2 asking), VRay recomputes surfaces that have already been computed in the first view, am I wrong?
          I tried to push the parameters on a test scene, and it seems that for an identical POV (eye distance at zero) it takes the same time to compute the 2 views...
          it would be nice to use the left eye samples and complete it on the fly for the right eye, like the "multiframe incremental" mode would do for a "fly through" animation.
          Paul.
            Nope, it doesn't. It just checks if new samples are needed.
            This is exactly what it does now.
              maybe I'm doing things wrong, but I have SP5, on max 2009 x64, a VRayStereoscopic helper with eye distance at 0.0, focus method on "none", view "Both" and adjust resolution ON... with irradiance map set on "very high" I ensure you that it spends the same time on each eye... so I'm a bit confused
              I join my test scene if you want to check...
              thanks!
              P.
