you could workaround - set all objects properties to NOT receive GI but the obj you like
renderIRR to file in low settings
reverse GI obj prperties and boost GI settings
"incremantal add to current map" your GI
reset GI obj. properties and render GI "from file"
__________________________________
- moste powerfull Render farm in world -
RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
You can also use the "Use irradiance map" option in the VRayMtl material to turn it off and use brute force GI for this material - might be useful for small but detailed objects.
Using an IRmap for primary and a LC for secondary bounces, how can I control the number of bounces and subdivs for brute force when turning off "use irradiance map"?
