Clean Alpha Channel Please
  • Clean Alpha Channel Please
    Hello All,
    When rendering out to a TGA file with an alpha channel, how do you prevent that fine outline around the objects? I can not get a clean alpha without the ghost line at the edges.
    Thanks,
    Scott
    Make sure your background is black in max, any enviroment lighting in the Vray overrides.
    Make sure pre-multiplied alpha is not checked when saving the tga.
    If all else fails in photoshop after you have masked the layer with the mask, select:
    Layers-> Matting-> Remove Black Matte or (if you have a black fringe)
    Layers-> Matting-> Remove White Matte or (if you have a white fringe)
    Layers-> Matting-> Defringe (1-2 pixels is all you need )
      the alpha channels are right. the fine outline comes from transparent pixels, because of the AA. this can't be avoided. it's a known problem.
      like bob-cat said make sure your environment color is white or black. or take the photo from the environment as background to pre-multiply the pixels from it to the rendering.
      I thought the tga format has this option to pre-multiply the alpha so it generates a thicker outline around the RGB channel of the image to avoid the outline. the alpha isn't affected by that.
      best regards
      themaxxer
      Pixelschmiede GmbH
      www.pixelschmiede.ch
