Hello,
I'm a newby in animating with vray and was trying out the generating IR / LC and then proceeding with final rendering animation. I have been following the tutorial http://www.spot3d.com/vray/help/150SP1/tutorials_anim2.htm. I finally got somewhat of the idea of how this works but had some questions regarding rendering parameters when generating both steps. I’m trying to produce an exterior animation that will be played on a LCD screen for our client. This tutorial doesn’t say anything about the Image Sampler, Color Mapping, and DMC Sampler.
1. Should the parameters for all these be the same for when I Generate LC/IR Maps (first step) and Rendering Final Animation (second step)?
2. These are the parameters I’m using for:
IMAGE SAMPLER
Adaptive dmc
Mitchel Netravali
COLOR MAPPING
Hsv exponential
DMC SAMPLER
Adapt amount: .85 min samples: 4
Noise thresh: .02 global subs: 2
Are these o.k.?
3.Should the output type and output size also be the same for both steps? (I would like to use HDTV)
Any help would be great,
Thank you
