Missing maps on client when using DR
  • Missing maps on client when using DR
    I have two machines running Vray advanced 1.0903g.
    One is running as server and client and the other one is just a client.
    I have a scene that I wish to render using the DR. All materials has been setup using UNC - so they should (and do) work over the network.
    The problem is - I can render the image running max from the client NOT using DR and get a correct image WITH the map, but when i render the image from the server using DR and both machines I only get mapping on the server buckets.
    Any ´s are very welcome.
    razz,
    maybe late ... well you can use maxs' network rendering and check INCLUDE MAPS in network render dialog.
    tomas.
      I have had the same exact problem for the last few vray versions. UNC paths are working fine. Once in a great great while I'll get a full imge.
      Tom4ski-Include map is a feature of Backburner (max's network rendering). Are you saying you are using backburner and render to VRAY DR? I never considered this an option for stills.
      Corey
      Corey Rubadue
      Director
      Chaos Group
        Corry, i'm sorry. it was my nonsence. i'm using max-net render only.
        just in case .. this might help: http://www.chaoticdimension.com/foru...pic.php?t=2477
        tomas.
          For peace of mind...is anyone using DR with the latest build and getting consistent results? with no network mapping problems?
          corey
          Corey Rubadue
          Director
          Chaos Group
