Pre-calculate the pre-pass of the VrayFastSSS2
  • Pre-calculate the pre-pass of the VrayFastSSS2
    Hi there,
    I'm doing a little animation with fastsss2. I have pre-calculated the IR and LC but when i'm doing the render, I have the pre-pass of the FastSSS2 that calculate before the final rendering.
    Is there a may to store that information like the Ir and the LC? And is there a way to use"use camera path" ? That would be extremely useful and win a lot of time.
    Thanks
    Stan
    3LP Team
    No ideas ?
    3LP Team
      It has been requested before and we'll do it, but for now it will have to be re-calculated.
        Is this possible now, with the newest vray?
        TD at http://brinkhelsinki.fi
        3ds Max 2013 with VRay 2.30.01.
        Win 7, Intel Xeon X5675, Nvidia Quadro 5000, 48 gb ram.
          Yes, it has been implemented since a long time. The VRayFastSSS2 material allows you to save and load the illumination map from disk.
            Hi Vlado!
            I see options for saving and loading a single frame, but nothing for sss frame blending or "use camera path" as in the original question by 3LP?
            I guess "use camera path" would be tricky as SSS is more view dependent than in example GI?
            Thanks in advance.
            Edit:
            I see that the prepass phase looks a lot different when rendering from a still camera than from an animated one. I guess some kind of frame blending takes place here? We just don't have any control over it?
              Interpolation Frames and Use Camera Path features are not available in VrayFastSSSMtl.
