Massive improvement with GeForce cards -please read
  • Massive improvement with GeForce cards -please read
    I just found a magic button for Massive improvement with GeForce cards if you use lots vray proxys...by the way it's always been there....I just never tried it
    Go to the Vray Proxy Display Tab & change the default setting to FACES .
    It's that simple
    I checked my Scene statistics and the Frames per sec went from 23 to 337 !!!!!!!!!!!!
    Now that's how a bloddy GTX 480 SHOULD perform.
    I should have known this all along as I knew game cards shaded faces much much quicker than edges.
    Anyway I hope this helps all of you guys strugling out there with game style cards.
    [I don't see why it wouldn't be the same for ATI cards as well.
    All the Best
    Jamie
    o.o u've been using proxy for all that time and never checked their display settings? nice 1 ^^
      I had always used the display setting but only used EDGES or BOX mode.
      But it's funny how we never try things that are right in front of us.....only problem is with vray & max there are thousands of things right in front of you that you don't get time to try.
      Cheers
        Yea... I know ur feeling :/ why aren't we more smart haha
          Thanks for the tip.
          Another thing for speeding up gaming cards is to select all objects,
          rightclick,
          select properties and disable backface culling.
          Reflect, repent and reboot.
          Order shall return.
            Rotl really backface are speading up ? :O I only used it for blueprints -.- thanx !
              Holly s**t!!
              Thanks a lot. Disable backface culling for all objects and from maybe 5 fps there are 200 fps !!!! I have brand new GTX 580 and there is a real power, thanks a lot!!!
              AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
              2D | 3D | web | video
              jiri.matys@gmail.com
              https://gumroad.com/jirimatys
              https://www.artstation.com/jiri_matys
              https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
              https://www.instagram.com/jiri.matys_cgi/
              https://www.behance.net/Jiri_Matys
              https://cz.linkedin.com/in/jiří-matys-195a41a0
                guys i think you invited wheel .... and some tips for ATI users ?
                  I was under the impression that this is general knowledge
                  It also works with ATI cards.
                  Gaming cards don't like edges/lines/wireframes.
                  Displaying faces only is much, much faster.
                  Marc Lorenz
                  ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
                  www.marclorenz.com
                  www.facebook.com/marclorenzvisualization
                    My GTX love wire frame, and smooth but it hate wire+ smooth... weird...
                      Oh, when I discovered back face culling it was like I bought a new computer!
                      www.hrvojedesign.com
                        My GTX580 drop framerate to half when I am using "preview from file (faces)" instead of edges. And switching backface culling has no influence.
                        Regards
                        BLADE
                        Edit: Now I see. The effect reverses when in wireframe mode.
                          Is there a way to make back face culling the default?
                            Preferences / Viewports:
                            Left side, upper half:
                            [ ] Backface Cull on Object Creation
                            Regards
                            BLADE
                            • #15
                              Originally posted by tammo View Post
                              Thanks for the tip.
                              rightclick,
                              This works with the new fermi Quadro cards (Quadro 4000). Tripled viewport FPS in wireframe on 365k poly (350k vert) scene
