RE_Light_Select - Automated?
  • RE_Light_Select - Automated?
    Heya
    Em just went through youtube vids and have to say that that RE_Light_Select got my attention, something similar to Vue 9 relighting engine...
    But I kinda hit the wall so I was hoping that maybe some1 nice would script it or chaosgroup would add it later on...
    Basically listing 100+ lights in render elements would take ages so I'll appreciate to get some script to list all selected lights plox...
    From other hand any plans for adding indirect illumination and so on ? And caustics...and shadows...and everything else we can stick in ;O
    When I upgrade to Vray 2 at the end of the week I'll write a script for this, should be fairly easy.
    Maxscript made easy....
    davewortley.wordpress.com
    Follow me here:
    facebook.com/MaxMadeEasy
    If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
      Blass you ! Thanx let me know when u finish plz : )
        I'll do it as well if Dave doesn't get to it. Once I get 2.0.
        Colin Senner
          I've written the basics of it, but not on 2.0 yet...
          If someone who has Vray 2.0 can type this into the Maxscript listener and paste the output here please I'll finish making it, just need to know the correct property.
          Showproperties VrayLightSelect()
          Follow me here:
            -- No ""showProperties"" function for VRayLightSelect
            GHiOM = Guillaume Gaillard
            freelance 3D artist
            www.ghiom.com
              Sorry
              Showproperties (VrayLightSelect())
              I'm just guessing the name, but should be correct I'd imagine...
              Follow me here:
                .enabled : boolean
                .filterOn : boolean
                .atmosphereOn : boolean
                .shadowOn : boolean
                .elementName : string
                .bitmap : bitmap
                .vrayVFB : boolean
                .color_mapping : boolean
                .multiplier : float
                .lights : node array
                .lights_exclude_type : integer
                false
                  OK basic version to test... Haven't got Vray 2 to test it with but syntax should hopefully be ok.... should work in all max versions.
                  LightSelect_Element_maker.zip
                  Follow me here:
                    Made change so you can choose to add selected lights as one Light Select Render Element instead of having a Render Element per light. It's got a basic incremental numbering system built in but it might cause duplicates if you run it on seperate sessions.
                    Code:
                    --Light Select Render Element Maker
                    --Written by Dave Wortley
                    --Version 0.2
                    --Untested
                    --Makes a Light Select Render Element per chosen Light.
                    try(DestroyDialog DW_LightSelect) catch()
                    AR_lightList = #()
                    AR_LightSelect = #()
                    P = 1
                    rollout DW_LightSelect "Light Select Render Element Maker" width:297 height:300
                    	listbox lbx_allLights "All Lights" pos:[6,10] width:127 height:17
                    	listbox lbx_selectLights "Selected Lights" pos:[162,8] width:127 height:17
                    	button btn_add ">" pos:[138,31] width:20 height:44
                    	button btn_Remove "<" pos:[138,80] width:20 height:44
                    	button btn_make "RE per Light" pos:[134,258] width:157 height:17
                    	button btn_all "All" pos:[138,128] width:20 height:44
                    	button btn_makeMulti "Add selected as one RE" pos:[133,279] width:156 height:17
                    	on DW_LightSelect open do
                    		for o in objects where superclassof o == light do append AR_lightList o.name
                    		lbx_allLights.items = AR_LightList
                    	on btn_add pressed do
                    		--add
                    		if lbx_allLights.selected != undefined then
                    			append AR_LightSelect lbx_allLights.selected
                    			lbx_selectLights.items = AR_LightSelect
                    			deleteItem AR_LightList lbx_allLights.selection
                    	on btn_Remove pressed do
                    		--remove
                    		if lbx_selectLights.selected != undefined then
                    			append AR_LightList lbx_selectLights.selected
                    			deleteitem AR_LightSelect lbx_allLights.selection
                    	on btn_make pressed do
                    		--make elements
                    		theManager = maxOps.GetRenderElementMgr #Production
                    		--for o in selection where superclassof o == Light do
                    		for o in AR_LightSelect do
                    			theManager.AddRenderElement (VrayLightSelect elementname:("LightSelect_" + o + "_") lights:#((getnodebyname o)))
                    			--print (getnodebyname o)
                    		--Messagebox (AR_LightSelect.count as string + " Light Select Elements Created")
                    	on btn_all pressed do
                    		--add all
                    		if lbx_allLights.items.count != 0 then
                    			for i = 1 to lbx_allLights.items.count do
                    				append AR_Lightselect lbx_allLights.items[i]
                    				lbx_selectLights.items = AR_LightList
                    			AR_LightList = #()
                    	on btn_makeMulti pressed do
                    		--make elements
                    		AR_MultiLights = #()
                    		for o in AR_LightSelect do append AR_MultiLights (getnodebynameo)
                    		theManager.AddRenderElement (VrayLightSelect elementname:("LightSelect_" + (formattedprint P format: "02d") + "_") lights:AR_MultiLights)
                    		--print ("LightSelect_" + (formattedprint P format: "02d") + "_")
                    		P += 1
                    CreateDialog DW_LightSelect
                    Follow me here:
                      Haaa wow love u ! How do I use it now ?
                      U so good in it any chance to get that thing for mate too ? ^_^ Select object > mate? ^^
                        Just goto Maxscript ->new script, copy and paste that into a new script, and then select-all (in the editor) and drag the text onto the toolbar and it'll make you a button to use it with.
                        Once run it'll automatically populate the left list with all the lights and then you just add the lights you want to have as light selects, pressing the first button will make a render element per light, or if you want to have say 5 lights in one pass then just add them to the list and then press the 2nd button, and it'll make one RE with all the selected lights in one pass.
                        Follow me here:
                          Thanks you it's working !
                          Now we can think about the workflow and options it's needed .
                          Can we supposed to use layers also ? I'm usual to group my lights in differents layer.
                          freelance 3D artist
                          www.ghiom.com
                            Will have a look at doing layers as well... I can probably just add a button for use selection instead... then you can just select the layer contents and do it that way....
                            Any more feedback welcome...
                            Follow me here:
                            • #15
                              Ok added options for using selection... should mean u can set it up according to layers pretty easily. You can select a whole layer and it will only process the lights, no need to only select lights.
                              Code:
                              --Version 0.3
                              --Version History
                              --Added ability to use selection
                              --Add all lights as combined
                              --Initial Version
                              AR_lightList = #()
                              P = 1
                              	button btn_Selection "Sel" pos:[138,176] width:20 height:44
                              		--add
                              		--remove
                              		--make elements
                              		--add all
                              			AR_LightList = #()
                              		--make elements
                              		P += 1
                              	on btn_Selection pressed do
                              		--add selected lights
                              		AR_Lightselect = #()
                              		AR_lightList = #()
                              			append AR_Lightselect o.name
                              			deleteitem AR_LightList (finditem AR_LightList o.name)
                              		lbx_selectLights.items = AR_Lightselect
                              Follow me here:
