Different render results betveen 1.5 and Vray 2.0
The speed is different because the render results are different; as to why they are different, I am not sure. If you send me the scene to vlado@chaosgroup.com, I will be able to tell you more.
VladoI only act like I know everything, Rogers.
For those who read this thread, the problem with different renders is resolved in build 2.002 (thanks for speed support to Vlado) there was some bug with lights. The difference in render speed is beacuse the render from Vray 1.5 was rendered in 32bit max and the Vray 2.0 render in 64bit max, and 64bit max is slower when the proxies are enabled. Here is the workflow to disable it from Vlado (go to the Common tab of the Render Setup dialog, click on the "Setup..." button in the "Bitmap performance and Memory Options", and turn off the "Page Large Images to Disk" option. Then save the scene, restart 3ds Max and re-open the scene.) And it realy helps a lot, now with disabled proxyes the rendering speed is practicaly same as in Vray 1.5 32bit
Thanks a lot Vlado
