Why is Rendering Effects doesn't work with DR?
  • Why is Rendering Effects doesn't work with DR?
    I'm sorry if this has been asked before. I'm new here.
    But how do you get max Rendering Effects to work if you
    render with DR? What's the trick?
    It's working OK if I don't use DR. But I get no Rendering
    Effects at all if render using networks / Distributed Rendering.
    Thanks in advance,
    Regards,
    Re: Why is Rendering Effects doesn't work with DR?
    Hm...
    I must be missing something really big here...
    Either no one is having the same problem. Or I must
    be so blind to see where the problem is.
    Regards,
      because the system that collects the DR image parts don´t have all informations you need for render effects.
      i think it´s not to complicated to make render effects work but at this time it will not.
      someone correct me if im wrong.
