Linear Workflow with max and Vray
  • Linear Workflow with max and Vray
    I'm sure most of you guys are experts on linear workflow and gamma 2.2 but for the newcomers, I wrote a blog entry today about it. If your a little lost on the subject check it out.
    http://www.ruffstuffcg.com/journal/l...in-3dsmax.html
    Ruff
    Great! It has everything in really simple and understandable form.
    Could you also mention the adjustament needed to vrayMat raytrace threshold?
    Default 0.01 isn't enough anymore. Should be like 0.005 - 0.001.
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
      could you explain what you mean about the vraymat raytrace threshold Lars?
        I meant the cutoff value in vrayMat options which is 0.01 default.
        When rendering using linear workflow, it has causing troubles/errors in many cases.
        Reflections are being cutoff too early and wont be rendered as they should.
        Lowering cutoff value to 0.005 or even lower should correct it.
        Lasse Kilpia
        VFX Artist
          Thanks for your effort, its really apreciated here.
          Arch Pedro A. Solano
          "Save the irradiance map, save the render"
          Vray 3.10.03|3DMax 2011 x64|Intel Core i7-2600 CPU @3.4GHz|16GB Ram|Windows 7 Ultimate SP1
          Follow us on facebook
          Visit us on PSolano
            Posted some of the general pitfalls that can happen with this workflow. Hoping it helps.
            http://www.ruffstuffcg.com/journal/p...-workflow.html
            Fred
              Hey Lars,
              I got the impression that when turning on 2.2 gamma color mapping, but not affecting the render would compensate for the contrast change on all the controls in Vray?
              Can anyone verify that?
              Fred
                I was reading this tread the other day and some others on the forum re: LWF. I ran some tests with the MAX gama set to 2.2 2.2 1.0 (output) and and the following Vray CM settings:
                Linear 1.0, 1.0 2.2 with DAC checked - looked fine in FB but dark in Photoshop. Save file as a .tif
                Linear 1.0, 1.0, 2.2 with DAC unchecked - Colors washed out in FB but image was correct in PS
                Linear 1.0, 1.0, 1.0 with DAC unchecked - Looked fine in FB but dark in PS
                Then I changed my MAX settings to 2.2, 2.2, 2.2 (output)
                Set my Vray CM to Exponential 1.0, 1.0, 1.0 looked good in FB and looked good in PS
                So I'm confused about your settings. Do I need to be saving my image to EXR to get your settings to work?
                Vince
                Vincent Jaramillo
                Smithgroup
                301 Battery Street
                San Francisco, Ca 94111
                  No, but you need to specify the output gamma to be 2.2 in the save file settings´gamma options.
